Knock knock
actually, While they may be different sizes, I believe they are the same thing. From a "make it work" perspective, as long as they're bolted to the block and wired in, they should work.
if you can mount it, then just get a pigtail to fit whatever you need and splice it.
Ok the sensor has two wires. A black and a yellow wire. As far as I can tell the truck side has only one wire leading to the connector. Are both black and yellow wires hot or is one of them a ground? Thanks
