Late ignition switch
Looking for diagram for late ignition switch I’m working on55 F100good need help
Can we ask why you are looking for this?
If I remember correctly,,,,,,,,,,,,,,,,,,,,the switch is mounted on the lower left side of the dash to the left of the steering column. It has a multiple wire plug that gets pressed on to the switch assy. There is usually a battery feed , a wire to the ign coil, and a wire to the starter solenoid (through neutral safety sw or clutch safety sw) .There may also be a wire to supply accessories. Have you removed the old sw yet? |
