loads of rear end play
Old Apr 22, 2010 | 09:35 AM
juangoodude's Avatar
Exclamation loads of rear end play
Help all,
I just had an Eaton tru-track, moser 31 spline axles, and a ford motorsport gear set, 373 ratio, installed.
I have a Tremec 3350 5 speed, and an aluminum d-shaft. The lash is correct as well as everything else. Problem, I have at least 2" of roll at the tires when in gear. The clutch is a duel friction with an aluminum flywheel.This condition is worse when in motion when I load the drive train then decelerate, (drive / coast.) Forget going down a hill, The car bucks in and out. Is this normal? I'm waiting to snap the universals right out of this thing!
Old Apr 23, 2010 | 05:12 AM
david paul's Avatar
sounds normal to me at the tires (that doesn't sound like much backlash at the gears)
jerxia8039
Oct 14, 2010 02:34 AM
RandysFT
Sep 27, 2006 04:43 PM
oscar7777
Sep 6, 2006 09:08 AM
