-   -   need help (https://www.fordforum.com/forum/general-tech-11/need-help-15204/)
mark81976 Dec 6, 2008 04:57 PM
need help
IH i need help with my 1993 markVIII. last week i took it to the auto parts store to have it scaned and it died and it wont start.check the fuel no fuelpresure to the intake.had it towed home it set for a mounth and it started run for 20min i shut it off and started back up.is my fuel pump bad.are do i have a bad relay if so were is the relay located at..thanks for anyhelp
fblevins1 Jan 7, 2009 06:16 AM
RE: need help
You might want to check your fuel filter first, could be a cause to your problem and a much easier fix, and not too expensive even it not the cause. I don't know your level of Mechanical expertise so I am hesitant to direct you further into your fuel troubleshooting.
But in the future when you post for help, put capture words in the Subject so Members can tell if you have a problem they might be familiar with, in this case something like "1993 MarkVIII will not start" Proof reading your post might help project that "can do" and get your post more attention too.
I think the Forum Mods are going to bust my chops now. (ooops)
