Is this normal Down Stream O2 sensors read .830v
Old Apr 27, 2023 | 07:33 AM
Tomb1956's Avatar
Default Is this normal Down Stream O2 sensors read .830v
Hi all
2015 Ford Flex SEL, Dealing with the dreaded CATs. P0430 code. Car is at 110K. Before I spend the 2000.00 for a CARB approved CATs. I want to go through it. My OBD scanner live data show both Rear sensors steady but at a higher voltage than what I read about rear O2 sensors. I've read or YouTube says should be about 450mv. Now my Scanner reads Milliamps for the upstream sensors. And I get the switching signal and looks normal. But I can't find what would be nominal range. At idle both switch between +45ma and -45ma. Anyone have any insight to the rear cat voltage level. Right now this would indicate rich condition. That needs corrected before I change the expensive parts.
B1S1 & B2S1 switching measured in milliamps.
B1S2 & B2S2 Steady at constant RPM about .830mv.
OBD2 reader Launch 123E. Just hoping for a comparison against another one. I just trying to interpret what I am seeing.
Also Fuel Trims Short and long are slightly negative or positive. but hover at zero.
Thanks in advance.
Old Apr 27, 2023 | 01:50 PM
When are you doing the measuring? If the converter has not reached a high enough temp it can't function correctly.
The ideal thing to measure/see is the graph of the voltage. The graph should after the second converter should be almost a horizontal line. Near .(.5 )+,_ a few tenths of a volt.
Don't forget the meter is giving you averages because it is not capable of responding that quickly.
Old Apr 27, 2023 | 02:11 PM
Tomb1956's Avatar
Thanks For Replying, The Converter was above 1000 degrees. And the yes its stable Flat line within the the .5 that you mentioned. Just seemed to be a higher than expected.
Just realized I put a decimal point in my post It's 830mv not .830mv.
Last edited by Tomb1956; Apr 27, 2023 at 02:19 PM. Reason: Correction for earlier post
Evan09
Jul 11, 2022 11:55 PM
wildernessbob
May 8, 2022 04:27 PM
skip1930
Jan 26, 2013 05:19 PM
