O/D light flashing".......any thoughts???
Old Sep 7, 2008 | 08:39 PM
wrapreynolds's Avatar
Default O/D light flashing".......any thoughts???
Howdy,
I'm Nelson....a USAF officer stationed in west texas........have a 2001 F250 4 x 4 (actually converted and it runs off of Veggie Oil....runs great).
Anyway....driving home from the deer lease....noticed that the OD "OFF" light began to flash.....pulled over, reg the owner's manual, turned the engine OFF/ON....it reset, but within a few moments (like the first shift), the light came back on.
I know that the OVERDRIVE still works....i could press the button, and you notice a definite shift and change in the RPMs (increase).....and after I press the OD button again, the RPMs shifted down, but the "OFF" button still remained on.
Optimum cruise for me on the HWY is around 63 MPH (should be somewhere around 1550ish RPMs), but in this case....it was around 2200-2400 RPMs.....
Any ideas...
Mucho thanks...
vr
Nelson
Old Sep 7, 2008 | 10:43 PM
Default RE: O/D light flashing".......any thoughts???
Welcome to the site Nelson..
The best thing to do would be to have someone read the powertrain trouble code with a scanner forbetter direction.. The OD lamp flash/ON is indicating a pending trouble code.. Could be the TCC clutch solenoid(torque converter clutch) circuit or connector issue if you lose OD selection, or as simple as the wire/s running up the selector lever rubbing through on the column.. With the lamp flashing, and if aloss of OD function, I'd think it was possibly a solenoid issue.. Could be a trans overheat/temp sensor issue as well.. Slip/ratio could be a reason fo the lamp indication as well. Being you state that the cruise RPM's are now higher, would indicate that the OD is canceled..
Old Sep 7, 2008 | 11:02 PM
Thanks HP.....
I bought a aftermarket warranty......so if it is a MAJOR thing.....it's at least covered.
vr
Nelson
PS.....love the Helmet/Mask........I flew A-10s and now teach in the T-38C......
Old Sep 8, 2008 | 04:52 AM
Use Common Sense's Avatar
Has the tranny ever had the fluid/filter been changed? I have seen tired fluid cause selonoids not operate properly. If you do a tranny flush, make sure that you go the extra mile/cost and drop the pan cover to replace the filter.
Old Sep 13, 2008 | 07:45 PM
chemoman's Avatar
First let me thatnk you for serving our country and protecting our freadom.
I stumbled upon this link
http://www.clubfte.com/users/monsta/...TrannyFAQ3.htm
tomcat5
Aug 10, 2021 05:10 PM
TruckChick4X4
Sep 14, 2009 08:13 PM
Claymore0421
May 13, 2008 09:53 PM
Trader4Less
May 2, 2005 05:40 PM
