Pioneer/Clarion nav radios
If I have a 2009 Ford Escape, would I have the option to put either a Pioneer/Clarion navigation OEM radio in my vehicle?
Will either be able to be programmed to my car? |
For a 2009 Escape, you will need the Xanavi/Clarion HDD Nav.
You will also need the following to complete the install assuming your car has SYNC: Replacement Right side steering wheel control Antenna Splitter Extender Cable Amplifer Amplifier Harness Procedure 1 & 2 Harness with Sync Pins (available from United Radio) United Radio sells everything you need as a kit, and can also program the vehicle to your vehicle. You will also need a new dash bezel that comes from the ford dealer. |
Ford sport trac radio
I have a 08 sport trac adrenalin. It does not have the navigation radio in it. It does have micro soft sync and blue tooth and 6 disk cd. I was wondering if I can put an 09 explorer ford navigation radio in it and will it work.. Ford dealer is absolutely no help...
You may be able to put an 09 radio in, but it's not meant to be put it that car and you may run into a lot of compatibility issues with SWC & Sync. Also the 09 will require an external amp.
I would recommend just putting the 08 Pioneer Nav in, like what would have came with the truck. All you'll need is an 8A2T-18K931 nav unit, Map, Antenna, and have the unit programmed to your vehicle. |
Originally Posted by DMarafino
(Post 70418)
You will also need the following to complete the install assuming your car has SYNC: Replacement Right side steering wheel control Antenna Splitter Extender Cable Amplifer Amplifier Harness Procedure 1 & 2 Harness with Sync Pins (available from United Radio) United Radio sells everything you need as a kit, and can also program the vehicle to your vehicle. You will also need a new dash bezel that comes from the ford dealer. We have 2 units on us right now. part numbers are AL1T-18k931-AE and CC3T-18k931-AA |
The CC3T is for a superduty, but should work in the 2012 Escape. The AL1T is not meant to work in an 08. Any factory NAV unit you put in a car will require programming to the car in order to work.
2011 nav
Do you have a oem nav for 2011 superduty? Please let me know.
