-   -   Power Window problem on an '04 F350 (https://www.fordforum.com/forum/general-tech-11/power-window-problem-04-f350-10262/)
Stuntdog56 Oct 26, 2007 11:58 AM
No power to the circit breaker (#601 30amp) in the fuse box. I can run 12V to the bottom slot where the breaker fits and all the windows will work. Is there a relay under the hood I need to replace?
david paul Oct 26, 2007 01:41 PM
RE: Power Window problem on an '04 F350
THAT WOULD BE THE FIRST PLACE TO LOOK WHERE ALL THE RELAYS ARE
Hayapower Oct 26, 2007 02:44 PM
First, check fuses F2.35/10amp, and F2.41/10amp in the Central Junction Box (CJB) under the dash panel, left hand/drivers side.. These are Instrument Cluster/Battery Saver Relay feeds, and the Accessory Delay Relay (that supplies/controls voltage out to fuse 601/30amp) gets its coil power to close the delay relay and then complete the circuit from a closed/energized Battery Saver Relay.. The battery saver relay is a non replaceable and integrated to the cluster, but the Accessory Delay relay is a replaceable unit in the CJB.. Could be just the Accessory Delay Relay.. I can send you the relay connector/face view,and you can check for voltage to the connectorand/or bridge the connector to prove out the relay..
Stuntdog56 Oct 29, 2007 07:58 AM
Please send me the relayconnector face view
Hayapower Oct 29, 2007 01:06 PM
Sent..
