-   -   replacing upper control control arm bushings (https://www.fordforum.com/forum/general-tech-11/replacing-upper-control-control-arm-bushings-5328/)
shel67 Sep 22, 2006 03:26 PM
hi, my 1995 ford aerostar has a worn upper control arm bushing on the driver's side. I've been quoted up to and over $300 to fix problem. I came upon a tool that supposedly removes and replaces upper controle arm bushings for late model ford vehicles wthout having to remove the upper arm assembly. Is this correct, and if so can anyone give me advice to fix problem?
shel67 Sep 25, 2006 08:40 PM
RE: replacing upper control control arm bushings
cant anybody help?????
masterexploder Sep 25, 2006 09:13 PM
i suggest you take it to wherever quoted you $300 it is pretty labor intensive to replace, and i don't know if you want to put that much effort into it or not.
sticks1158 Oct 13, 2010 05:32 PM
Upper Control Arm bushing replacement
MasterExploder
Thanks for your post! I feel a lot better, as I just had the driver's side upper control arm bushing replaced on my '96 Aerostar, and thought $225 was a bit pricey. Judging by your post, I should feel fortunate! Thanks again.
