swapping motors
I have a 1988 Ford F150 2 wheel drive 4.9 litre standard transmission pickup. I also just purchased a 1992 Ford F150 2 wheel drive 4.9 litre automatic transmission. What I am finding is everything seems to be the same except the motor mounts. I am trying to find out if i can put the motor from the 1988 standard into the 1992 automatic. My Ford tech isn't sure and told me to go to a junk yard and ask them if it is comperable. Can anyone help me out. The motor in the 1992 has a lower end rap and the 1988 runs excellent. Help Please
RE: swapping motors
They are the same. Might have to change electronics to the '92 on the '88. [/align] |
RE: swapping motors
All you should have to do is. On the crossmember where the mount sit in they should be ajustable atleast mine r and the 94 is the same as the 92.
RE: swapping motors
Try to browse around the net, there are auto shops online that has highly engineered assistant that always available to answer you querries. They also offer high strength and heavy duty parts like Ford F150 Pickup parts.
