Timing Issue
Old Sep 10, 2009 | 06:32 AM
nz2x3q's Avatar
Default Timing Issue
Daughter spun 2 rod bearings on a 95 Windstar with a 3.8. Am having trouble setting the cam sensor. TDC on #1 cyl., compression stroke, I found a plastic tool on the net and when I install the sensor with the arrow paralell to the crank the sensor is about 90 degrees out from where I removed it and is blocking the install of the intake manifold!!!! What is the proper procedure??? I have the proper manual but it seems vague.{or I,m a dunce!!}.Thanks for any help,,,,PL
NickTurbo
Apr 1, 2012 09:21 AM
FIRE RANGER
Dec 6, 2009 01:17 PM
Qaiphyx
Apr 4, 2008 11:59 AM
tim1028
Jan 29, 2008 12:00 PM
railboy36
Aug 5, 2007 08:42 AM
