-   -   Tranny fluid type (https://www.fordforum.com/forum/general-tech-11/tranny-fluid-type-17383/)
mjohnst123 Jun 22, 2009 02:44 PM
Tranny fluid type
I need to know the type of tran fluid that is used by my 1988 motor home that is a F350 cab and has a 460 engine. The front seal was leaking so the tran was dropped and a new torque converter put in and replacing the seal. Now need to fill with fluid and not quite sure the type. Don't have the owners manual for the vehicle. Thanks for any help
Use Common Sense Jun 23, 2009 05:07 AM
You would need MERCON or MERCON-V Automatic Transmission Fluid or dual usage fluids
labeled MERCON/MERCON-V. MERCON Automatic Transmission Fluid is no longer be
manufactured as of July 1, 2007, therefore, availability of this fluid will only continue for however long it takes to deplete what remains in inventory.
