Trouble shooting turn signal
Old Apr 22, 2008 | 08:10 AM
slimecoat's Avatar
Default Trouble shooting turn signal
Im trying to to get the turn signal on the boat trailer to work. It seems the problem is with the tow vehicle. (98 ranger)
The passenger side turn signal on the trailer doesn’t work. The driver side does
Both turn signals on the truck work.
The green wire on the trucks electrical plug is dead. The circuit tester doesn’t light up
All fuses on the truck seem to be ok
What do I do now?
Old Apr 22, 2008 | 11:04 AM
Default RE: Trouble shooting turn signal
The fuse in the IP fuse box position #3 7.5ampis good/hoton both sides when tested?
Old Apr 22, 2008 | 11:16 AM
Put a 12v tester on the #3 fuse, with the muilti function switch selection for the right side the power to the fuse should flash/cycle.. The trailer lamp function and truck lamps are separate circuits through the multi function switch...
Glowbug
Jan 28, 2022 12:43 PM
pixleyyy
Mar 27, 2007 11:08 PM
sntidesne
Feb 7, 2006 11:43 PM
harlem
Jan 16, 2006 03:35 AM
bingermann
Oct 31, 2005 01:36 PM
