The ultimate oil
http://www.lubedealer.com/triams/
AMSOIL Signature Series 0W-30 Synthetic Motor Oil is the industry benchmark in lubrication technology. Engineered with the world’s finest synthetic base oils and high performance additives, AMSOIL Signature Series 0W-30 is designed for those who demand the absolute best in motor oil performance. The exclusive “extended drain” formulation delivers superior engine protection and maximum fuel economy. AMSOIL Signature Series 0W-30 is a premium grade synthetic motor oil that exceeds the requirements of modern, high-performance engines and older engines. It replaces other 0W-30, 5W-30 and 10W-30 motor oils and consistently outperforms competitive conventional and synthetic motor oils. AMSOIL, the leader in automotive synthetic lubrication, produced the world’s first API qualified synthetic motor oil in 1972. Trust the extensive experience of AMSOIL The First in Synthetics® to do the best job protecting your engine. Extends Drain Intervals AMSOIL Signature 0W-30 Synthetic Motor Oil lasts much longer in service than conventional oils. Its unique synthetic formulation and long drain additive system resist oxidation and neutralize the acids that shorten the service life of other oils. AMSOIL Signature Series 0W-30 delivers the best possible engine protection, cleanliness and performance over extended drain intervals, reducing vehicle maintenance and waste oil disposal costs. Maximizes Fuel Efficiency The lightweight molecular structure of AMSOIL Signature Series 0W-30 Synthetic Motor Oil reduces energy loss from the “drag” common to high viscosity oils. It is fortified with additives that enhance its friction-reducing properties to help further improve fuel efficiency. Reduces Wear AMSOIL Signature Series 0W-30 Synthetic Motor Oil contains specialized anti-wear technology. Its durable, high temperature film strength effectively separates metal surfaces to reduce wear even under the most grueling conditions. Tests prove that AMSOIL Signature Series 0W-30 provides better protection against wear than other motor oils (see graph). AMSOIL Signature Series 0W-30 helps engines last longer. http://www.amsoil.com/graphs/sso_4ball_400px.gif Resists Heat, Reduces Oil Consumption and Emissions AMSOIL Signature Series 0W-30 Synthetic Motor Oil is thermally stable with a strong resistance to high temperature volatility (burn-off). It is heavily fortified with detergent and dispersant additives designed to prevent sludge deposits and keep engines clean. Low volatility and clean operation reduce oil consumption and emissions. Provides Outstanding Cold Flow Properties Unlike conventional oils, AMSOIL Signature Series 0W-30 contains no wax. Its exceptional -60°F cold flow properties ease starting and reduce bearing wear. APPLICATIONS AMSOIL Signature Series 0W-30 Synthetic Motor Oil is recommended for use in gasoline engines, diesel engines (API CF, ACEA B5) and other applications requiring SAE 0W-30, 5W-30 or 10W-30 with the following worldwide specifications: • API SM/CF, SL, SJ … Mixing AMSOIL• ILSAC GF-4, 3 … • ACEA A5/B5-04 • GM 4718M, 6094M • Ford WSS-M2C929-A • Honda HTO-06 • Daimler Chrysler MS-6395N • VW 503.00 AMSOIL Signature Series 0W-30 is compatible with conventional and synthetic motor oils. Mixing AMSOIL motor oils with other oils, however, will shorten the oil life expectancy and reduce the performance benefits. AMSOIL does not support extended drain intervals where oils have been mixed. Aftermarket oil additives are not recommended for use with AMSOIL motor oils. Service Life AMSOIL Signature Series 0W-30 Synthetic Motor Oil is recommended for extended drain intervals in unmodified(1), mechanically sound(2) gasoline fueled vehicles as follows: • Normal Service(3) – Up to 35,000 miles or one year, whichever comes first. • Severe Service(4) – Up to 17,500 miles or one year, whichever comes first. • Replace AMSOIL Ea oil filter at the time of oil change up to 25,000 miles or one year, whichever comes first (other brands at standard OEM* intervals). • In all non-gasoline fueled vehicle applications, extend the oil change interval according to oil analysis or follow the OEM* drain interval. |
