water coming out spark plug holes
I have a 02 focus and there is rusty water seeping out spark plug holes. Is this a bad head gasket?
Thanks |
Very possible.
Do you get a white smoke puff when you get on the gas? |
Check for white smoke, oil in water, and water in oil. remove all plugs and do a compression test aswell as coolant pressure test. If the plugs are in tight nothing should get past them when making a good seal. you sure its not coming from something over head and leaking down?
