window
What should I look for when the power rear window won't work on 02 Sport Trac?
Blown fuse or possibly bad relay. Bad motor or possibly bad switch. I usually check fuses first. If fuses are good then go to the motor and see if there is power to the motor. If there is power there, the motor is bad. If there is no power, look for broken wire or bad switch.
| All times are GMT -5. The time now is 07:56 AM. |
