| Davetheslave |
Aug 27, 2006 02:29 AM |
Window motor on 95 T-bird
The window motor on my 95 T-bird is not going up gets stuck half way up and if you push the switch and push the window with your hand it will go up. I am trying to replace the motor, but it is tight in there also do I have to remove the rivites, and do the passenger side and drivers side swap out can one be used for the other because if I get one at the junk yard probably passenger will of had less use. any help is greatly appreciated because the Hanes manual is not much help at all.
