1989 Ford Bronco 2
Hey guys. Could use some help.
Ford Bronco 2 1989 Fuel Injected 2.9 L Fuel injectors not firing. Node light tested. Runs if I spray started in intake. Replaced ECU, still nothing Getting positive current at fuel injector, not grounding out from ECU, I think? Help!!! Thank you for any input. |
Originally Posted by Landmann
(Post 129523)
Grounding issue
I pulled a wiring diagram and tested for positive current at the fuel injector wire at the motor. I got good current 12.7. When I read the ECU was supposed to ground out the fuel injector to make it fire I thought the ECU was the issue. It did not solve the problem. How would you suggest I diagnose going forward?
