98 mustang window problem
hey guys, still stumped on my power window problem. need help. pass window will only go up on pass window switch, no down. nothing on master side. changed switches and got new motor. no change. drivers window fine! HELP!!!!!
Have you checked the master switch on the drivers side?
yes sir i have. the switches are seperate and i have changed it out twice.
2 Attachment(s)
Is there current at the window motor? If there is current coming out of the master switch and none at the passenger switch, look for broken wire. If there is current at passenger switch and none at motor, look for broken wire in door. Here is a diagram that might help.
Attachment 2525Attachment 2526 |
Way 2old provided a nice diagram. If you haven't found the wire problem yet , may be able to help direct you to the proper wire to check. Do you have a test lite or meter to use?
yes i do hanky. this should get me started. thank you all so much for this info..
way 2old, your the man! i will put this new info to the test tomarrow! thank you!
problem fixed guys! it was a wire between the door. thanks guys for the help!
Thanks for posting your repair. We love to help and really appreciate the replies to what fixed the problem.
