f-550 axle removal
need help cant get left front axle out of 2006 f-550:(
I believe you need to remove the front differential housing cover. Then rotate ring gear and remove the bolt that goes through the carrier assy ( 8 mm) and holds a block in place so the axles cannot move inward. Remove bolt, block and "C"washer on end of axle. Axle should be able to be removed now.
thought that might be the case wanted to make sure first, thanks for the help.
