seat belt chimes
I PICKED UP MY BLACK 2005 FX4 SATURDAY THAT I ORDERED IN FEBRUARY, LOVE THE TRUCK BUT THE SEAT BELT CHIME IS DRIVING ME CRAZY. CAN ANYONE TELL ME HOW TO UNHOOK THE CHIME.
I GOT UNDER THE SEAT AND UNPLUGGED WHAT I THOUGHT WAS THE CORRECT WIRE TO DISABLE THE CHIME, BUT THE AIR BAG LIGHT IN THE DASK STARTED FLASHING BUT THERE WAS NO SEAT BELT CHIME. BUT I PLUGGED IT BACK IN AFRAID I HAD DISABLED THE AIR BAG ALSO. PLEASE HELP. |
RE: seat belt chimes
i just buckled the seat belt behind me, and sat down.....im not a fan of seat belts....
THANKS PATRICK,
I ALREADY DONE THAT, BUT WHEN YOU SIT DOWN YOU SIT ON PART OF THE BUCKLE. NOT VERY COMFORTABLE. THANKS FOR THE REPLY!!!!!!!! ANY BODY ELSE HAVE A SUGGESTION? |
well, you could find out where the chime is, and cut the wires to it...
you could look at the fuse chart for the fuse that makes it, or the chime, work, and pull it.. you could find an old seat belt buckle, and snap it in, then pin it back, or push it down between the seats, so youre not sitting on it... |
THANKS I'LL TRY THAT,
SURELY ONE OF YOUR SUGGESTIONS WILL WORK. THANKS AGAIN! |
if you pull the fuse, should you find out which one handles the chime/seatbelt system, BE CAREFUL that tghe fuse is not piggybacked with some other system like the airbag system, so on...
if you really got into this, you could take the female end of the buckle, and find the sensor, which is likely simply an electric connection which the buckle completes, or a little button that the buckle pushes in, and either push the button down and glue it, or take a small piece of metal and complete the circuit. |
THANKS FOR THE INFORMATION.
I'M GOING TO WORK ON THAT SUNDAY. THANKS TO EVERYONE FOR THEIR HELP. |
hey there big guy
i bought a dog leash seatbelt, hooked that bad baby right into the seatbelt buckle and now it doesn't chime anymore. Also not a huge fan of seatbelts
hanky, my guy, put a lid on it ok?
Reconnect the electrical connector, clear codes, buy a dog seat belt harness or buy just the buckle clip from pull a part.
Someone somewhere will be sad if you die from not wearing a seat belt though. |
