Vibrations
I Have a 2003 escape xlt with a nasty vibration in the front right (i think) when i turn the wheel all the way to the right it gets really bad !! i have replaced the axle shaft( not intermediate) but did not help ! i see they had alot of transmission problems any help would be appreciated ! thanks for any help
Welcome on a board !!
Check out this link may its help |
Hi,
Would like to know if you actually changed the parts or had someone else do the work. If you did it , you will be more likely to answer my questions than if someone else did the work. |
i did the work myself !
Brake rotors can sometimes be the cause of vibrations.
Did you notice any differences with the engine cradle when the wheels were turned to the right as compared to the left?
vibrations
i did not notice any changes in the cradle but i will check closer today ! i did notice that the mounts have alot of movement when i put it in reverse ..ie the motor moves more then when in drive ..
Keep in mind that the engine and trans can move into a difficult angle that the half shaft may not be able to accommodate. Engine and cradle mounts need to be in good shape to keep that movement to a minimum. Let us know what you find.
vibrations
Thanks alot Hanky i do have it on stands with the suspension hanging ! I will let it down and try it !!!
Will i let it down and took it for a ride and viola no vibrations !! thx again Hanky !!
