2011 ford Escape XLT, rear windshield Nozzle no wiper fluid coming out.
Front works fine, rear nozzle not dispatching and fluid on the rear windshield.
Has anyone had this problem before, if so what is the fix.
Please help.
My alldata software covers up to 2007 any car so below diagram is from a 2007 Escape 3.0L.
As you can see, if your hose stays connected to the pump but there is a small break somewhere in the middle, you still should get little bit of fluid, due to low pressure, coming out from the nozzle. It's not practical to check, so the easiest way is to borrow the front pump by swapping the hose, then activate the front and see if you get fluid from the rear nozzle.
What else to check, of course is the pump itself you can bench test it or you can simply swap the electrical connector. The pump for front and rear should be identical. This test should tell if you have a bad pump.
Lastly it's the wiring, check the relevant fuse.
