C6 trans problem.
Old 07-17-2017, 03:58 PM
Dukecougar76's Avatar
Default C6 trans problem.
I was at the track this weekend went up to make a pass after I did my burn out and I let off the gas it felt like the rear wheels locked up because of the breaks. I had the car towed back to the pits and after a little bit of searching around I found that the trans break solenoid was crap. Will this cause the rear wheels lock up because it keeps throwing it in reverse by accident I was at the track this weekend went up to make a pass after I did my burn out and I let off the gas it felt like the rear wheels locked up because of the brakes. I had the car towed back to the pits and after a little bit of searching around I found that the trans break solenoid was crap. Will this cause the rear wheels lock up because it keeps throwing it in reverse by accident because of the solenoid.
Old 07-20-2017, 10:16 AM
Their designed to hold 1st and reverse for a lockup, without being able to cancel the trans brake R solenoid it seems it would always want to lock any movement..
conanalois
08-31-2013 06:16 AM
jamey624
07-16-2007 07:36 AM
RangerPA
11-04-2006 01:31 AM
Seirpin
10-09-2005 10:24 PM
xkikbxr
10-22-2004 03:15 PM
Quick Reply: C6 trans problem.
