Firing order
Does anyone know of a Ford engine that uses a
1 8 4 3 6 5 7 2 I know this is a standard Chevy order.. Best |
I don't !
Why do you ask ? |
Ford V-8's fire 1-3-7-2-6-5-4-8
hello hanky, raski
I ask the question because I heard on a TV show that Ford uses the firing order... raski shows a different firing order. I have been on the internet and find that does not show as a Ford firing order either. https://www.onallcylinders.com/2018/...02-h-o-engine/ hanky I ask because I don't know everything, The page above shows many of the firing orders... the firing order I mentioned is a typical chevy except for the LS the TV host forgot to mention this fact.... as you can see by the list.. Hey thanks for your input... Best BTW I just found that web page this morning... did not see it yesterday... |
Just type in your search section , Ford firing orders, and it should provide just about all the firing order info for Ford.
hanky
when you don't know the answer, shut up |
Sanddoc, sorry if my question might have ruffled your feathers.
Many times people ask a question because they are working on something and in order to help prevent them from getting into problems it helps to have some ides of why they ask. I don't need to discuss my qualifications over the net , but we learn when we don't know the answer , be honest and say so. A little FYI , you will note firing orders on most GM 8 cyl engines ,except one or two others, will start with the numbers 1-8-,,,, Fords don't do that, hence my I don't know answer. Thanks for your input. |
sorry Hanky for being rude to you...
| All times are GMT -5. The time now is 02:34 AM. |
