1977 Ford pinto 2.3L cylinder head question
Old May 19, 2021 | 11:44 AM
Mikey57's Avatar
Default 1977 Ford pinto 2.3L cylinder head question
Inside of the exhaust port, there are small holes that taper out and come out below the exhaust ports. Never seen anything like it. Question is can i use a late model header from a 2.3L ranger or does someone make a header that matches the holes? Thanks in advance
Old May 19, 2021 | 09:41 PM
Welcome to the site..
Thermactor air ports, where the air pump would inject air as part of the emission system, Smog.
Old May 20, 2021 | 09:12 AM
Mikey57's Avatar
thank you. I kinda thought it might be emissions. I want to put a header on so I'm thinking I might weld up the holes. I'm afraid if I don't weld them that the header gasket will blow. Thanks again.
JWStiles65
Nov 7, 2017 03:23 PM
tbarron
Aug 18, 2011 10:23 AM
david_wil
Feb 22, 2011 11:32 AM
mach1mustangman
Aug 13, 2009 06:20 AM
FORDEXPLORER
Jan 6, 2007 03:14 PM
