460 timing problems
Old 07-23-2018, 12:54 PM
shedhunter's Avatar
Default 460 timing problems
Hey I'm new to this but I thought I'd try it out. I've got '71 Ford highboy I replaced the original 360 in it with a 460.a few years ago. Lately when I shut it off it wants to keep running I believe it's called spark knock. It don't do all the time. I've moved the distributor a little in both directions but nothing seems to help. I'd appreciate any help someone might have.
Old 07-23-2018, 01:35 PM
I believe it was called "dieseling or run on".
I also believe they used an idle stop solenoid mounted on the carburetor that when the key was on it idled at normal idle speeds. Then when the key was turned off the solenoid would drop back and close off the throttle plate thereby preventing it from getting any air/fuel and preventing it from dieseling.
Old 05-15-2019, 09:05 PM
bobwhite's Avatar
throttle solenoid solution in the previous post will work. if you have an auto trans, you can try keeping your foot on the brake when you stop to park and leaving the transmission in "drive" while you turn off the ignition. this will load the engine down and keep it from dieseling. you can also try running the next higher octane gasoline. if your idle rpm is adjusted too high, it can contribute to dieseling occurring or make it worse.
Joe Reeves
07-14-2017 07:58 AM
beaglerock
05-30-2017 09:33 AM
Joe Reeves
05-20-2015 06:03 PM
neuma181
03-16-2014 09:34 AM
87e350fix
12-11-2011 11:46 AM
Quick Reply: 460 timing problems
