4.6L fits what else?
Old 08-30-2011, 08:07 PM
west coast noob's Avatar
Default 4.6L fits what else?
Having overheating issues with a 97 Lincoln towncar which originated with the heater core going bad causing the initial over heating. now the problem has risen again.
Heads were milled 2 years ago so a second go seems iffy. Am considering a used engine swap. Anybody know what other years and models may fit, or point me in a direction to look? OR will this engine handle a second milling? No experience with fords (doing this for my mother)
Thanks
Old 09-27-2012, 09:07 PM
tempforce's Avatar
have you chemically cleaned and flushed the cooling system. be sure you purge all of the air out of the system or you will have overheating issues…
while the system is open check the radiator for corrosion/blockage..
make sure you are set at the proper timing and using the proper grade of fuel for the higher compression due to the milled heads…
Makowski
03-31-2011 01:58 AM
Hagar44
02-01-2009 10:03 PM
illycut
03-04-2008 08:19 PM
buffalojump
04-12-2007 01:25 PM
johnguitarplayer
02-19-2007 08:40 PM
Quick Reply: 4.6L fits what else?
