83 escort transmission
How do you adjust the neutral start switch on a manual transmission... I just replace the engine .. The used engine was from an automatic car.... It was complete with wiring harness which i left on.. I did have to figure out how to make the car start from the inside . using the key switch...
However you have to put the car in reverse to start the car now.. 1983 .. 4 speed manual .... 1.6 carb |
