Aod 84 replacing 91
You can change the linkage from trans to the other by pulling the pan . You should check to be sure that tail shaft lenghts are the same they do have 2 differant lenghts and also the drive gear teeth for the speedometer you need to count teeth on the gear on the shaft otherwise speedo might be off. Other than this it should work.
Good luck
Good luck
corder13
Nov 23, 2004 06:42 PM
