New here. Can anyone help with C4
Old 06-25-2017, 09:47 PM
gtojohnny's Avatar
Default New here. Can anyone help with C4
Hello,
I am new here and I need help with my C4 trans. I have a Green Dot Trans circa 1967-68. I have removed the pump to change the shaft and pump seal. When I did, I found a small pin sitting at the bottom of the pump mounting surface. I cannot figure out where it came from or where it goes. It looks like some type of centering or metering pin. Can anyone help? Thanks!
Attached Thumbnails New here. Can anyone help with C4-dscn1605%5B1%5D.jpg   New here. Can anyone help with C4-dscn1606%5B1%5D.jpg
Old 06-26-2017, 05:47 PM
I do not recall seeing anything like that in the trans. Might be a good idea to look closely for a blind hole in the trans case where that might be an alignment pin for proper positioning of the pump housing assy. There should be a corresponding hole in the pump housing for that pin to fit into if that is the case.
Craig Emerson
03-11-2012 04:09 PM
f150guy4
03-08-2011 05:46 PM
borgrif
04-01-2007 01:58 PM
billy jolliff
05-17-2004 03:35 AM
NikkiH
05-01-2004 09:00 AM
Quick Reply: New here. Can anyone help with C4
