A.O.D. tranny questions
is anyone familiar with the early 80's model aod? they have a drain back hole in them and if you put the front pump seal in just wrong a little bit the seal plugs the hole allowing the fluid to leak past the outter metal of the seal and the front pump case. i want to know if the hole is supposed to be located at the bottom or the top of the casze?
