Trick to pulling shift cable???
Old Aug 21, 2008 | 10:49 PM
CW's Avatar
CW
Default Trick to pulling shift cable???
I have a 93 F-150 that i am rebuilding and i am trying to get the shift cable off at the aoutomatic tranny, Is there a trick or special tool needed?
Old Aug 21, 2008 | 11:14 PM
Default RE: Trick to pulling shift cable???
Just unsnaps off the range selector lever.. You can use a couple flat blades and gently pop it off.. Be sure to use equal pressure behind the cable connector end to move it off.. Some light lube helps on the install..
Old Aug 21, 2008 | 11:16 PM
CW's Avatar
CW
Thankyou, it looked like it should snap off but i didn't want to break it.
Old Aug 21, 2008 | 11:18 PM
Ground up build, or just the engine/trans??
Old Aug 21, 2008 | 11:23 PM
CW's Avatar
CW
Pretty much a ground up with the suspension and possibly the frame from my 91 F-150 ext cab 4x4. Currently has 4" suspension lift but is going up to 6" plus a 3" body lift. On 315/75/16's now and looking into 38.5/14.5/16's for it. Also considerind a solid axle leaf spring swap as well. Its my mud and trail truck that rust and a few trees got the best of, thats why im rebuilding Lol.
ArchiacPlague
Jan 7, 2015 12:42 PM
toddinav
Nov 5, 2012 03:33 AM
pur1964ford
May 4, 2007 02:04 AM
chopdrop
Mar 12, 2007 06:47 PM
perfectford1
Sep 14, 2006 09:58 PM
