2000 Windstar engine shaking
Shakes while sitting idle and gets worse at 1.2K RPM but clears up at around 2k+. Pulled each injector and each cylinder is firing. No codes. Motor mounts and harmonic balancer looks fine. I'm down to balance shaft and flywheel or torque converter. How do I check those without tearing down the engine? 3.8 SEL
Keep seeing people mention the EGR, but never considered it to be the problem. I had the intake clam shell off a month ago and made sure all the EGR ports were clean. The only thing I can think of that would cause this is the EGR valve being stuck open. I will check it today and post back thanks.
I vacuum pumped the EGR valve and it stalled the engine, so it works and there are no codes. I ran a mode $06 and it came up with several fails, but nothing significant. I can post those if you'd like but I don't think they're related.
https://www.justanswer.com/ford/11e3...ts-bounce.html
