2001 windstar driver window wont go up
window will go down but not back up. replaced motor same problem. any ideas, is there a switch or module I dont know about? The switch for window does have power.
I think it is probably the switch on the door itself.
Can you pull the panel again and temp wire it to the passenger side switch just to see if that makes it work as a test? |
