93 Ford Aerostar...What's wrong?
I have a 1993 Ford Aerostar, 3.0L, 2 wd. I have not had any problems with it until a few weeks ago. I started it, and then it died right away. I thought it was a little strange, but I started it again, gave it a little gas, and it was fine. Drove fine. Got to where I was going. Left about 10 minutes later, same problem. During that next week (I drive 25 miles one way to work), it got to the point where it didn't wanted to stall after start and would have to constantly give it gas to keep it running. As soon as I would put it into reverse or drive, it would stall. It would stall in stop and go traffic. It would stall stopped at a light. Drove fine as long as I didn't have to stop or At that point, the check engine light never came on. Boyfriend thought it was spark plugs and distributor cap so those were replaced. Same thing was happening, but getting worse. I would basically have to drive with one foot on the gas pedal and one on the brake on stopping so vehicle didn't stall. When started (if I can keep it started), it will initially start out with the idle just fine. But after the first 5 seconds or so, the idle drops and all the gauges drop with it (oil & voltage). Was also running very rich and using a lot of gas. Boyfriend thought it was the O2 sensor, so he replaced that yesterday. This morning, it started just fine and idled OK. Drove it to the gas station, it restarted fine. Drove it about 5 miles and it stalled at a stop light. Restarted fine, but as driving on the highway, the check engine light came on, then went out, then came on, then went out, then went on and stayed on. What are some possible things that could be wrong. I suggested to my BF that he check the IAC valve and fuel pressure regulator, MAP or MAF sensors, but he just told me that I should stay out of it because I'm a girl and I don't know anything about cars. I was going to go buy an OBD-I code reader from Walmart, but he told me that it wouldn't be worth it. I plan on stopping at Autozone on the way home from work today (if it makes it) to see if they can read the codes for free. Any suggestions on what could possibly be wrong?[&:]
RE: 93 Ford Aerostar...What's wrong?
New boyfriend
Just joking, I think you got it, IAC. Very easy to give this a try. Remove it and clean it with some carb cleaner.
Here:
http://www.autozone.com/servlet/UiBr...3d8014aa59.jsp
good luck
Here:
good luck
1997 Ford Aerostar
Please let me know what finally worked. I know sometime you fix and change so many different things that you don't know what solved the problem in the end.
jpwy
01-27-2012 08:49 PM
steelgal58
09-23-2009 06:33 PM
davidbiggato
03-15-2007 02:39 AM
