Cruise Control Doesn't Work
Old May 26, 2017 | 01:01 AM
tb30570's Avatar
Default Cruise Control Doesn't Work
Brake lights work
Speedometer works
horn works
Fuses good
servo 10 pin connector -
  • pin 7 has 12 volts compared to ground
  • pin 9 has 12 volts compared to ground
  • pin 10 has 12 volts compared to +12v battery
  • when connected to the servo, the voltage between 5 and 6 changes from ~7 to ~9 volts when the on button is pushed (should this go from 0 to 12 volts?)
  • the on button sends 12 volts to pin 5 compared to ground
  • there are 2.21k, 686 and 124 ohms between pins 5 and 6 for resume, set and coast which is pretty close to 2.20k, 680 and 120 ohms
  • there is no connectivity between pins 5 and 6 when the off button is pushed
Does it sound like one of the clock springs is disconnected or does it sound like the off button just isn't making a connection?
is the voltage range between 5 and 6 normal?
Old May 26, 2017 | 01:10 PM
tb30570's Avatar
servo was defective. replaced with salvage yard servo for $21 and it works now.
imamacuser
Apr 18, 2015 01:06 PM
MGood777
Aug 2, 2010 09:53 PM
Thacashstream
Dec 10, 2009 05:55 PM
opie4487
Jul 10, 2008 06:34 PM
93f250xlt4x4
Sep 3, 2006 09:59 PM
