over heat
95 windstar,3.8 recently started acting upo. temp gauge and warning beep say overheat,doesnt smell warm or seem overly hot when stopped. Replaced thermo no solution,did notice fans not running. I jumped motors they work. Any thoughts by others that it may be a relay or? I'm lookin for relay but dont know where it is and what it should look like.HELP
RE: over heat
Yep the fans gotta work, If you got a 2 fan system one should come on as soon as you turn the AC on , As for the controller I'am not sure where they put them. You should be able to go to any of the chain auto parts store an they can either tell you , Or let you look it up in a service manuel if they have one for your model vechile
RE: over heat
you gotta find you one of them manuals...think they are called Haynes or something...can't quite remember what they are called, but the auto stores should have em...they're awsome when it comes to tsing
RE: over heat
i believe there is a resistor for that as wewll
| All times are GMT -5. The time now is 08:15 AM. |
