| daddyblaize |
Aug 25, 2023 07:01 AM |
Steering Stiffness
Im also experiencing this same kind of steering stiffness. I will take a good look under the car at the U-joint and see if a lube will help. I’d just got it to stop leaking PS fluid yesterday after changing the pressure hose—what a pain. Since I figured it might be the pump and mine is a lifetime warranty flavor, I figured “eh why not?”. Turns out that only caused me more time and hassle than it was worth when I had to break the seal on a perfectly fine connection that wasn’t leaking. After replacing the pump though now comes the pressure line leak at the fitting (you know from the back of the fitting that’ll never stop ever in life until you replace the hose entirely?) so now with new pump, new pressure hose and tight leak-free connections I’m still struggling to steer the Windstar just like before. Yaaayy!!! I’m tired, but (more broke than tired so) I’m stuck with the Windstar for now. The rack is only a year old so I’m really not implicating it as the culprit. I’ll do the penetrant test on the U-joint and see if that fixes anything. If so I’ve got some lithium grease that’ll add more durable lubrication.
