What type of Power Steering Fluid in a 98 Windstar
Old Jan 13, 2009 | 04:26 PM
shrek4472's Avatar
Default What type of Power Steering Fluid in a 98 Windstar
Did have the following posted under another issue but reposted as it is slightly different now.
Well I have the pump changed, went fairly smoothly.
Steering is working fine but I still have a whine when the revs are picked up, quite as a mouse at idle even when I turn the wheel.
I bled the system by turning lock to lock about a dozen times or so.
The Parts Shop told me to use Mercon ATF fluid, is this correct?
So should I just run it for a while and assume it will go aways as the pump frees up and the last of the air bleeds out or do I have something more serious here? ID the Mercon fluid correct or not?
regards
Shrek
Old Jan 13, 2009 | 05:56 PM
Default RE: What type of Power Steering Fluid in a 98 Windstar
Mercon is correct..
Give it some miles to perk all the air out of the system.. Turning lock~lock will get the brunt out, but usually some run time is needed to purge all the air..
Old Feb 13, 2011 | 09:38 PM
Rickw574's Avatar
For a 1998 Ford Windstar the correct Power Steering Fluid these days is Mercon V Automatic Transmission Fluid. I called my Ford Dealer and asked, and I also read the bulletin that Ford issue in 2007 replacing all Mercon with Mercon V. The manual specifies ATF type F. I believe the spec was updated to Mercon and then Ford changed it to Mercon V per the bulletin. They do sell a DEXRON III / MERCON blend which they told me at the parts store I could use but I'd go with the Mercon V.
makuloco2000
Jan 31, 2014 09:35 AM
Otto
Jan 22, 2010 06:47 AM
mjohnst123
Jun 23, 2009 05:07 AM
FLJ
Mar 28, 2008 08:59 PM
87broncoll
Dec 18, 2006 08:02 AM
