-   Windstar/Aerostar (https://www.fordforum.com/forum/windstar-aerostar-30/)
-   -   WINDSTAR 2002 ABS BRAKES lights (https://www.fordforum.com/forum/windstar-aerostar-30/windstar-2002-abs-brakes-lights-31885/)
kamleshkumar_darbar Jun 3, 2014 07:58 AM
Hi,
I have a Ford Windstar 2002 and when I drive the ABS and the BRAKE lights keep comming on.
Please can you advice me on how do I check this out and what is causing this to happen.
Also how much is the ABS EBCM for a ford windstar and can it be repaired.
The vin no is 2FMZA52442BB70652.
I look forward to hearing from you.
Regards,
Kamleshkumar Darbar
katie85 Jun 3, 2014 02:13 PM
Most probably needs a new abs module, cost around £300/£400. If you google it its apparently safe to drive as it is.
Hope that helps
bluewind Jun 3, 2014 03:48 PM
to provide additional detail:
you should check if the the brake pressure switch that sits at the underside of the master cylinder is leaking brake fluid. You find it if you look over the air filter housing towards the firewall.
Make this a regular check or replace it immediately if there is a leak. Ford had a recall on this. If brake fluid leaks it will run down the wires and enter the harness at the ABS module. That stuff attracts water and this can cause a short resulting in fire.
The second issue its the ABS module itself. The printed circuit board is cracked and when the temperature goes up it disrupts some internal circuits. The ABS light comes on. In this situation you have regular brakes, no ABS.
There is no recall on this. Either live with it, replace it (about $1000 job) or have the ABS module repaired by for example: Automotive Scientific Inc. Your #1 Source for ECU, TCU, ABS, EBCM, Climate Control and Speedometer Repairs
