Audio / Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Need Help? Let Me Know!
Old Oct 3, 2011 | 10:06 PM
  #21
Mrt2004's Avatar
i have a 2010 F350 larriat and fully loaded. It come with a dvd player installed on the front dash as a touch screen. But i can only view the movie in park mode. How can i disable this? And one more thing how can i disable the beeping noise for not wearing a seatbelt?? thanks,
Old Oct 16, 2011 | 01:46 PM
  #22
murff21r's Avatar
not sure how to hook up my kc lights....88 ford ranger
Old Oct 17, 2011 | 10:24 AM
  #23
bigaudiofanatic's Avatar
There are a few ways to install your lights. The first is if you want them to come on with your headlights, find the wire that provides he factory lights with +, tap into that and run it to the active plug on a standard relay. Hook up the positive with at least 12 gauge wire to direct battery source.
The second is wire them to a switch which can get power at anytime but yet again run it to the battery using at least 12 gauge wire.
Or you can wire a relay to a switch so that you can not by accident leave the lights on and drain your battery unless the key is turned. For that use your 12 volt plug in your car to act as the pull switch on the relay than just run the power wire directly to the switch and to your lights. If you need more details let me know
Old Nov 7, 2011 | 03:56 AM
  #24
Lily001's Avatar
Are you a professional?I bought a 12vcity car dvd.I don't know how to install .I will ask my friend to help me.
Old May 9, 2012 | 08:30 PM
  #25
jron's Avatar
hi, i'm tryig to replace the rear subwoofer from 97 ford explorer
SAMF
Oct 4, 2008 10:07 PM
Mid West
11
Feb 3, 2008 08:46 AM
paddish
Jul 24, 2007 07:45 AM
AndrewMacks4.0
Oct 21, 2006 11:09 PM
CobieCane
Sep 7, 2005 02:08 AM
