Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
91 Bronco "clunk" mystery solved.
Old Dec 15, 2011 | 06:59 PM
uamsstudent's Avatar
Default 91 Bronco "clunk" mystery solved.
For years, I have had a "clunk" occur when accelerating from a full stop. Repeated inspections of the u joints did not indicate any problems. The problem was significantly more noticeable in hot weather. Recently, following the onset of cold weather, a loud repetitious squeak developed that occurred in unison with drive shaft rotation. Due to the annoying sound, the drive shaft was removed and examined. The Cardan Joint was found to be extremely stiff and non-flexible due to the wear of it's internal components. Following it's complete rebuild, all noises and clunks were eliminated.
Old Dec 16, 2011 | 08:07 AM
Thanks for the info. Have a Happy Holiday !
Old Dec 20, 2011 | 08:33 AM
Bullitt94's Avatar
Good info.
Old Mar 20, 2012 | 11:04 PM
747's Avatar
747
how do you rebuild the joint?
ptotoole
Nov 30, 2017 09:44 AM
billj818
Oct 23, 2017 07:14 AM
bigcars
Jul 12, 2010 10:17 PM
cdies
Jan 6, 2010 01:57 PM
iward3
Nov 16, 2008 02:52 PM
