oxygen sensor help 98 econoline 150
Old 05-19-2007, 07:31 PM
drlisz's Avatar
Default oxygen sensor help 98 econoline 150
Hello, my first post Ihave a ford Econoline 150 van it has 147,000 miles on the 4.2 litre 6cyl, I have a service engine light, the code says Bank2 sensor2, so i bought the sensor but which one is it passenger driver rear or front, I heard there is 4 but not sure anyone know
Old 05-19-2007, 09:25 PM
Default RE: oxygen sensor help 98 econoline 150
Welcome to the site...
O2's are positioned.....
Bank 1 is always the bank that cylinder #1 is on.. So bank 2 is opposite of 1.. Bank 1/cylinder 1is on the right/passenger side, so Bank 2 would be the left/driver side.. Sensorsrun,, Position 1 as most forward sensons, Position 2 towards the rear.. So,,, Bank 2, Sensor 2 would be the left/drivers, rear position... Also called catalyst monitors, a good/bad sensor can sometimes be diagnosed prior to purchase/replacement by swapping the right to left and see if the DTC follows the swap (bank/sensor position) since there's other issues that can set a code for a good sensor....
Old 05-19-2007, 10:18 PM
drlisz's Avatar
Thanks for the help Hayapower i wiil try and switch them if its not tohard to do so.
dmhowell
02-26-2012 10:47 AM
alair
06-03-2008 09:14 PM
1995PAPA
02-21-2008 08:48 PM
rlevy64614
10-15-2007 12:40 PM
mexiburger
10-23-2006 10:38 AM
Quick Reply: oxygen sensor help 98 econoline 150
