2009-2012 6F35 6 Speed Transmission LH Axle Seal Leak Repair
Old 08-24-2014, 09:53 PM
makuloco2000's Avatar
Default 2009-2012 6F35 6 Speed Transmission LH Axle Seal Leak Repair
This is a very common failure that most times goes unnoticed until the transmission starts acting up from low fluid level. When these fail they can really tear up the transmission bad enough the fluid is just pouring out and that is where it gets expensive. In this video I show you step by step what is causing all of this and just how to fix it. Even if you don't plan on attempting this repair it is good to know what to keep an eye on as potential failures. Hope this helps.
makuloco2000
06-02-2014 02:05 PM
hfb1957
06-01-2014 08:43 AM
hfb1957
04-02-2014 09:11 PM
makuloco2000
03-16-2014 02:50 PM
PTT
01-21-2013 10:47 AM
Quick Reply: 2009-2012 6F35 6 Speed Transmission LH Axle Seal Leak Repair
