smoking after head gasket repair
Old Jun 27, 2007 | 08:07 PM
mrmike's Avatar
Default smoking after head gasket repair
Hey,
I'm new to this forum and I'm having a hell of a time trying to figure out what could possibly be wrong with this escort i purchased and almost successfully repaired.
I bought the car cheap because it was a mess. The head gasket was blown( water in the oil, oil in the water), water pump was toast etc...
Ive replaced the head gasket, machined head(new valves and seals), water pump, timing belt, and various other gaskets/belts. That was the most pricey head gasket I've seen yet!
So I start the car and everything is great; thats is, until it gets warm (10 mins). Then it starts smoking like crazy. Blue to black smoke.
At first I suspected remnant oil/water in the exhaust/cat; but, after a hard drive around the block a few times its still smoking.
1991 Escort GT 1.8L
compression test: great spike with 165 psi across the board
Any ideas?
Old Jun 27, 2007 | 08:15 PM
mrmike's Avatar
Default RE: smoking after head gasket repair
I suppose i should add that it runs great/ starts right away and has lots of power on the road.
sorry for d-post.
Old Jun 28, 2007 | 09:08 AM
SYT's Avatar
SYT
Internal Fliud leak?
Old Jul 14, 2007 | 01:43 PM
whiteescort1.9's Avatar
Check the plugs, and oil level, and if the plugs are oil fouled and oil is low you are burning oil. If this is the case you will have to pull the head back off and check the head gasket to make sure it is not backwards or upside down, also check for deck warpage on the block, if it is off, it could cause a bad seal for one or more of the cylinders.
Christopher Brunelle
Aug 20, 2014 10:24 PM
makuloco2000
Sep 19, 2013 11:11 PM
flaco954
Aug 9, 2009 05:44 PM
mike0179
Apr 25, 2007 06:25 AM
JohnNetbee
Aug 1, 2006 09:34 PM
