Door ajar light
Old 05-05-2008, 10:47 AM
alightra's Avatar
Default Door ajar light
My door ajar light won't go off!! If I open the rear passanger door or the tail gate it will stay on all day. Is this a fuse prob. or a latch prob? Please help...it makes the lights stay on until I drive forward fast enough and I can't see when I back up.
Old 09-01-2008, 06:05 PM
Default RE: Door ajar light
You probably have a door ajar sensor failure.
This was common in the 2000 Excursions (I had 2 of them)
and some of the late 90's F150/Expeditions as well.
The lock actuators are the next to go. )
They are a bit tricky to change as they are inside the doors.
Get the parts online and do them yourself if you can, Ford wanted $300 per door
and I got all of the lock actuators and door ajars for less than that
and replaced every one of them at one time after I did onzies on one truck
and it started to drive me nuts.
There are left and right actuators, but I can't remember which the rear is - L/R.
I think there is only one door ajar sensor but make sure before you order 5 of them.
I think I got mine at rockauto but not sure...
Justin.
mike 96 ws6
09-25-2012 08:25 AM
oceanblue_2001
02-27-2010 05:16 PM
Zapman
02-16-2009 06:29 PM
Mike11C
05-27-2007 02:14 PM
sshupe
10-12-2005 02:12 PM
Quick Reply: Door ajar light
