03 Expedition 5.4L Cylinder #8 Misfire
Old 12-23-2010, 02:19 PM
coll0211's Avatar
Unhappy 03 Expedition 5.4L Cylinder #8 Misfire
Check engine light came on, read code, cyl #8 misfire, replaced all Plugs and Coil Packs, ran great for appx 2 weeks, started running badly, read code, #8 misfire: swapped #4 with #8 etc, reset codes, read code again, #8 misfire. Any suggestions or thoughts? I do not understand "why" it ran so good for appx 2 weeks and then #8 misfire code again. Even after I swapped #4 & #8, getting #8 misfire? I'm puzzled. It's running very badly. The spark plugs were not fouled or oil covered either time. I do not know what to do next!
Old 12-23-2010, 03:48 PM
Make sure the plug on the coil is tight and making good contact. Plug connections that were loose were known to give this condition. Also check for any possible vacuum leak at that location, all hoses.
haledonoem412
05-16-2009 04:20 PM
kilgore
07-05-2008 09:45 PM
miknwv
09-03-2006 04:16 AM
miknwv
09-02-2006 03:04 PM
Blueberry
09-02-2005 01:31 PM
Quick Reply: 03 Expedition 5.4L Cylinder #8 Misfire
