04 Ford Expedition 4.6L knocking / Rattle
Old 07-22-2016, 10:12 AM
Jacob Schwegel's Avatar
Default 04 Ford Expedition 4.6L knocking / Rattle
Here is the problem. When the SUV gets a little warm... It starts this knocking. (See video)
It sounds like its coming from the item in the video.
Thanks for any help!
Attached Thumbnails 04 Ford Expedition 4.6L knocking / Rattle-2016-07-22-09.34.01.jpg
Old 07-22-2016, 03:14 PM
I believe those are the catalytic converters. The substrate in one of them may have broken loose and could be the source of the rattle. Something you might check , make sure the flywheel flexplate is tightly mounted to the trans converter and not loose or broken.
Also, check the crank pulley (vibration damper) for the rubber cushioning broken loose.
There could be other possibles and hopefully someone will add them.
rocibecky
07-08-2013 06:16 AM
christyjoc
01-01-2011 07:25 PM
kevcoz
06-03-2008 07:07 PM
dale39
12-11-2005 02:44 PM
cwaire
12-16-2004 08:45 AM
Quick Reply: 04 Ford Expedition 4.6L knocking / Rattle
