Keypad entry code
Old 12-23-2007, 04:02 PM
mikedean65's Avatar
Default Keypad entry code
I just purchased a used 07 expedition yesterday. I asked for the pin code for the keypad entry and they indicatedit was unknown and the guy who could determine the code was not at work. The wallet cards with the factory set code is not in the glove box either. I my question is! Can I get the five digit Master code off the Antitheft module and second where is the module located. Thanks for any help. mike
Old 12-29-2007, 06:49 AM
Default RE: Keypad entry code
On my 2001 expedition the master code is located on the drivers side under the dash. Look for a Tan colored (maybe black also) box and it will have in large print the 5 digit master code for the door entry. I need to know what other options there are also. I do know if you put in your master code it will unlock the drivers door then hit 3 again and it will unlock all the doors.
Hope this helps
Dave
Old 03-16-2008, 08:20 PM
I just got a 2004 and I located my code behind the glove box it was on a small black box behind lots of wires. You will need a flashlight to see it. In my truck the code was upside down but it was easy to see once you found it. You could also try to get at the code from the fuse box panel. The panel is below the glovebox on the wall next to the door. When you get it off just look up and you will see a box on the firewall with white paper on it the code is in good sized numbers and all together. There were other things on the paper but I did not get to them so I dont know what they said.
Old 03-24-2008, 05:29 PM
any one figured out how to get the 2nd or 3rd code in? cause i cant seem to get them set...maybe im missing a step...but when i push 3-4 to let it know im setting the 2nd code...all it does is lock and unlock the doors, as a command from the initial code. am i just not reading the manual right? or what
sstinson
01-20-2014 05:15 AM
GendronFamily
10-16-2007 06:59 PM
Mikey_likes_it
06-13-2007 09:08 PM
Metalisean13
04-13-2006 03:09 PM
DeanoNC
01-06-2006 02:03 AM
Quick Reply: Keypad entry code
